Located in Ohio
Trailer: steel framing with heavy duty axle, not your typical single axle trailer. With aluminum decking that interlocks for not only an extremely durable but very light trailer. I pulled this with a jeep wrangler with Chem and water tank full.
4400psi 4gpm belt drive pressure washer
50ft pressure hose
2 hose reels
Over 300 ft of soft wash hose and supply line hose
7gpm bleach pump for soft wash
35 gallon Chem tank
Ibc tote for remote water access with shutoff valve
Multiple guns with various lengths
Extra parts box and extra soft wash pump
Jrod attachment
Blue turbo nozzle
Extension brush for easy gutter and high siding access
I will also give all my leads that come in after I sell the unit over to you if your local.
Unit only needs a battery, I use makita battery’s and can provide some if needed.
Looking for $5000 cash or partial cash with a dji drone.
Thank you for looking.
