Does anyone set up the outlet side of their trigger gun with a quick connect to change between lances and wash with their nozzles and a jrod? Just curious. I have thought about it then never did it. At 6’3" I am not the tallest of folks but certainly my back could use a little help here and there and even for the short 15 ft tall houses that I do not need the full reach of a lance.
Thanks,
Eric
That’s how I do it. I very rarely use a wand.
Sent from my DROID RAZR using Tapatalk 2
I use a 6" nipple and a quick connect for tips.
6" nipple? What does said nipple look like Thad?
That’s how ours is setup. QC for wands, nozzles, surface machine. Easy easy!
Sent from my iPad using Tapatalk HD
Sorry I missed this. I hope you didn’t Google “6 inch nipple” trying to get an example!
Four inch.
I tried that. I had problems hitting the peaks of 2 story homes about 28ft high. 5.5 machine. Could that be the reason. With the 3ft wand I have 0 problems.
John Devine. allwashedupny.com
No worries Thad… I had the feeling it was a piece of brass. I agree John, that is my thought as well. I think I will make one up for the spring as with the smaller houses and single story homes the 3 ft lance is not needed. I know Mike K. Uses a 18-24 inch lance on his gun.
I do up to three stories with that setup.
You’ll love not dealing with the lance.
Are you saying you use QC’s on the nozzle side of a surface cleaner or the inlet side?
Gun has female QC, wands, surface cleaner, and J-rods all are male QC.
Mine is 12 inches. You need to straighten out that water after the gun. Shoots better/farther than if it was just coming right out of the gun.
I rarely need a wand, shooter tip is all I need.
Which tips would you use for soap high and rinse high?
With my 8 gallon Pressure Pro I use a 0060 straight from trigger gun for soaping and rinsing. If you have a a 5.5 or 4 gallon I would probably think a 0040 would be good.
Where do you get your 12" wands?
Don
Fresh Look Pressure Washing
I saw one called the Ladder Saver, I thought it was kind of pricy, wonder if you could make your own with a threaded pipe of the same size with a connector and nipple. The one I saw was like $56.00. Just do a search for Ladder Saver.
12 inch Lance can be got from Russ at Southside.
Never buy a Ladder Saver. That guy needs to go out of business for the way he pitches his over priced piece of metal. It won’t shoot any further than a 0050 tip.
Thank you Michael.
