First time taking on a Trex deck, what is the best mix of chemicals? can someone advise me how to clean this type of deck.
Easy money. Requires a bit of finess though.
I have a hot enough mix that I can downstream and get great results.
If that’s not strong enough use a dedicated pump.
House mix is all you need. Let dwell. Then come in using a fan tip, strong enough to feel (with the hand) but weak enough to put your hand in. NOT a 40 (white tip).
Go over each individual board and you will see a hue come off of it. The results are great and the cash is easy.
