Can someone explain a basic roof mix, like where to start? I have been searching and haven’t found really anything! How much s.h./water/surfactant etc.? Thanks in advance!
Your meme was removed for vulgarity, Justin. - Steve
there is a lot of info about roof mix… search Lil more
You want to mix a surfactant like elemonator (or laundry detergent if you’re feeling cheeky) and you want 3-4% on bleach strength. So if you have 12.5% SH in your bleach then you want to mix a 4:1 ratio of water to bleach. Make sure to do a test spot to see what works. If it works instantly it’s too hot, should take a minute or two to start killing algae. It’s better to be slightly too strong than too weak, because it’s easier to dilute rather than add more bleach.
Also you will use a ton of bleach on roof cleaning so prepare accordingly. I’ve hear people will go through upwards of 30 gallons of SH for 1 roof.
Thanks for the reply, I appreciate the you helping with the question I had unlike some other people! I got some 30 gallon tanks I was going to use to start out with I guess I will go through it pretty quick. Do you spray a thin coat on or a thick coat?
Depends. Over use means you won’t have to reapply. Under use and you may have to go over it twice. Like I said, do a test spot first.
Alright, Thanks!
Dude, you’re sounding like me when you say “other people.” I started out in your same position, not searching and just asking questions. I’m not perfect and I sometimes jump the gun by asking first, search later, but when it’s easier and faster to use that little magnifying glass at the top right corner, you’ll be better off and gain more respect from everyone in here, rather than pissing them off for asking a question that could’ve had an answer found much faster.
Lol. He is getting what he asked for. The other new guy is telling him elemonator and laundry detergent. They make a good pair.
C’mon now man, at least you can wash your socks with it at the end of the day.
Search more
Didn’t say to mix them.
What is your roof wash mix? I assume then you use the cling-on roof additive?
Would you be willing to provide me about $7500 so I can buy equipment and then train me? Because that’s the impression you’re giving me, otherwise you’re just being a “sassafras”.
The wind up…the pitch…
The guy was looking for a cookbook for mix and they have one. Don’t know who you are or care. You’ve been on here two days and so far have been unimpressive. By all means please ignore anything I post or ask from here on in.
Sorry, I really didn’t mean to offend you. I was being sarcastic about Innocentbystander, he’s being extremely condescending without any real reason. I’m expecting him to call you a fool and say you know nothing just because you linked to a blog.
“You’re better than this.” -Brodie
Your not even trying to be clever anymore… I’m disappointed… I expected better
