It is said that pressure wash or power wash can cause damage to vinyl or wooden side while cleaning. So which is the best strategy that one can use to clean vinyl sided house?
soft wash
Rinse house, spray on soap,let dwell for a couple of minutes and then rinse clean= soft wash.
No damage and always easy money.
Good luck.
Thanks for your reply. But will it clean effectively and which cleaner we should prefer? As for soft wash we should use strong cleaner.
Yes. It’s pretty much the soaps you use that will do the job. The Powerwasher is used for wetting, applying and then rinsing.
As for the soaps we use, I pretty much mix my own concoctions that works best for us.
