What kind of wood?
The owner said this was painted wood but what is it? I have not seen the property. This was what the owner sent me.
Not sure why it matters. Just wash it
Looks painted to me…Wash that bad boy! Much success.
Yes it’s painted but I thought there were some issues with washing painted wood but I guess it would be the same as washing a painted deck.
Well, there are some darker pigments on Hardie board that I personally won’t mess with but what you’re showing is fine.
Some organic paints can be a problem, especially with darker colors. Usually you can see it more with roof washing with hotter mixes but I’m sure hw mix could lighten the paint a little too…I’ve washed all different colors, just do a test spot if you are unsure with a paint.
@DSJ1 you mentioned it being the same as cleaning a painted deck… how would you go about that? I landed a job where the customers got a white semi solid/maybe solid stain with lots of green organics on it, they just want the organics and dirt cleaned off so trying to plan my attack.
You took a job not knowing how to do it? How could you bid it without knowing what to do?
Maybe I need a break, this doesn’t make sense to me.
@Dirtyboy I’ve got a plan in place, was just looking for a second opinion. Thanks for the feedback though. PT pine is the wood. Their stain is chipping in areas and dirty. Just wanted a cosmetic cleaning to get the algae and dirt off and I wanted to get an opinion (before test spotting) on what others thought
House wash mix to clean a painted deck. If it’s really mad I may go up to 1.5% SH on a test spot. Just want to be careful to not peel the paint up or fade it.
@DSJ1 thank you! That was my plan from the jump. The paint is white to begin with so I wasn’t too worried about the bleaching effects but I’m a worry wart and want to ensure everything will be perfect. I really appreciate your feedback!
It’s definitely Balsa wood.
