What are these stains!? I hit them with SC, 5% bleach, and every tip. Nothing cleans it. These are high traffic areas and near a bbq. Maybe that has something to do with it?
Post a pic
Is this at a restaurant?
High traffic area at a BBQ place would likely make that grease/food waste tracked out by shoes over the course of time. Use a pump sprayer to apply some degreaser in a small area and see if it comes clean.
Yep apparently I missed first post. Degreaser is the answer
Did you prewet it before you applied SH
Yes. I first tried to hit it with SC. Nothing… then while it was wet (not soaked) I applied my 5% roof mix and let dwell then SC. Nothing… didn’t try degreaser though…
I would go with ebc
I dunno, if you look the darker areas are outlined by the roof overhang. If degreaser doesn’t work something else is going on there, like sealer, etc. I’m far from an expert though, just happened to notice that.
How did you apply your SH? I’d definitely try a strong degreaser on there.
With my 12v. 5%
Try a degreaser with some hydroxide in it. Report back. If you have heat, use it.
Ask if there was a sealant before using sodium hydroxide, if not…use a hydroxide mix
Test it first.
