So I just got my new antv5 hydrotek recovery surface cleaner that is preset to 5.6 gpm. I have their recovery vacuum system hooked up and was disappointed in its performance. The videos I saw on YouTube showed it picking almost all the water up and mine only seems to get about half of it. Is this normal? I checked my vacuum it’s sucking decently. The vacuum is down on the ground and I’m only using 50’ of vacuum hose…
Sounds like you are loosing suction somewhere
That’s what I was thinking. Those sc usually work as advertised right?
Yes. I would go back over your set up. Post some pictures maybe it just needs fresh eyes to look at it
