I’m getting ready to bid about 450ft of board fence that I will wash and paint black. It is in a backyard setting and I’m wondering what chemicals to use that won’t totally kill the grass around the fence.
If I DS 50/50, will the grass still die? Should I just white tip it and shy away from chemicals?
If it’s really hot out and the grass is already stressed you can burn the grass 50/50 DS. Wait till it rains before or after or just make sure to keep the grass wet. It will grow back. Just prepare the customer.
If you killed my horses grass id be mad
lol
Pre wett real good… Treat and rinse well after… you should be okay…
If you’re very concerned or the client, Id go lighter on the mix and have a helper scrub agitate with a soft brush to help it loosen.
