I am taking on a new opportunity and need to sell my setup.
Here is what I have:
2002 Ford E350 Van with Hot Water Landa Power Washer.
Van:
Decent shape with some body rust. Coil packs and plugs changed last year. Needs 2 tires and radio is broken. Runs great, clean title. 182697 miles.
Pressure Washer:
Landa Hot water unit
I have not used the burner in a year or so but it works. 8gpm 4500psi. 2006 hours. Oil always changed on motor and pump and it runs great.
The bad: needs new belts and grill on flywheel is broken. I have a new one and will include part in sale. Does not affect operations.
Also includes a 125gallon water tank, a hose reel with 200ft of hose, 2 pressure gauges, a reel with about 100 ft of supply hose, extension rod with brush, down stream injector kit. Everything you need to get started washing houses.
Setup is in use and needs nothing. It was used several times a week until recently. Can sell equipment alone without the van for the right price.
Contact me for photos. I will consider all offers.
Thanks!!
