Doing my first house wash, the house has vinyl siding… any tips and pointers?
Doesn’t get any simpler, what are your concerns?
Yes, put that machine down and do some reading
The pressure blowing the vinyl off
Thanks but no thanks for your help, u could’ve kept that to yourself. I thought this was the point of this forum
1-Make coffee.
2-Sit down.
3-Read while drinking coffee.
4-Thank Nick for his good advice.
5-Keep reading.
This forum is not to spoon feed the most basic information on the easiest thing there is to clean. Do some reading on here first, then ask questions. No one will answer you on this, sorry
Your concern about pressure blowing the vinyl off shows you have done no research what so ever on here about house washing.
Correction: you say no one will answer but the truth is we gave the most helpful answer we could have.
Don’t let these guys get to you. For vinyl siding mix jomax and simple green 50/50 and apply with pump sprayer or the injector on your machine. You can be aggressive with rinsing as long as you spray against the over lapping siding. Red tip is usually the preferred tip for rinsing. Good luck and welcome aboard.
Thank you so much, I really appreciate it
Who said no one will answer?
Definitely done research, but why not ask someone whos done it b4? No one told u to reply u could have kept your none helpful comment 2cents
What did your research teach you?
Eh, nevermind, listen to Innocentbystander recommendations
You’ll need scaffolding to get the proper angle. Even one storey. Spray downwards with the red tip like rain. Make sure scaffolding is secure.
Don’t give him bad advice, he’s trying to do the right thing and researching is time consuming when we can just give him correct answers of the bat.
Lol nope. My alt account is way more creative than this.
IBS don’t forget to explain the vaseline treatment on the soffit to avoid corrosion.
