I have a customer that has a vinyl picket fence with lots of mold on it. What is the best way to deliver the bleach and detergent mixture on this type of fence?
I do it also. The problem is that this picket fence has 1 inch wide pickets, seperated by 3 inches of open space. Each of the pickets has mold on all 4 sides. A lot of the solution will end up on the grass without ever hitting the fence. I was wondering if anyone has a technique for not wasting so much solution.
Shoot down the fence, not at a 90°. As parallel as you can so most of the mix hits the fence.
Good suggestion, Thad!
House wash mix for us too, there is no way I am scrubbing a fence to save solution. Dilution is the solution for grass and hit the fence generously with a house wash.
You could possibly brush it on to save some chem… But the time you lose doing that may not be worth it…
