Hi, I bought a used Rice Hydro DPH-3B with a Udor Kappa 43 pump (Honda GX160). When I tested it, the flow was surging badly. I opened the pump up: the diaphragms are all in good shape, but I found a small stone stuck in one of the valves. I removed the stone, changed all the oils, and tested it again. It is much better now, but it still pulses a little, and the needle on the pressure gauge bounces.
Is this normal for this pump? If not, how do I fix it?
One more detail: this pump has no pulsation dampener on it.
Udor’s manuals states:
Diaphragm pumps, by nature, have some pulsation.
Udor’s troubleshooting guidance states:
excessive pulsation is associated with air being drawn through the suction line or fittings, as well as incomplete priming.
So, mild rhythmic pulsation and a small amount of gauge flutter can be normal for a three-diaphragm pump without a pulsation dampener. A dampener just cushions the pressure/flow variation produced by the pump’s reciprocating pistons, it is not a device that makes the pump completely pulse-free.
What you are describing sounds more like air entering the system. Assuming you fully primed and purged it after reassembly. I would be looking for a suction-side air leak. Inspect the entire inlet/suction side for loose fittings, damaged seals, cracked hose, a poor strainer seal, kinks, or a hose that can collapse under suction. If all of that looks good then I’d re-check the valve that contained the stone. Removing the obstruction may have restored most of its function, but the valve seat or O-ring could still be damaged or not sealing fully.
yeah it sounds exactly like what Ohio thinks, air coming in suction. The gas roof pumps are super finnicky about their suction lines. I have 2 clamps on the suction hose going from my proportioner to my pump (AR30) because only 1 clamp SOMEHOW wasn’t enough. I blame the polypropylene fittings are not as nice to clamp as metal fittings (which you obviously can’t use on roof pump system).
