Uploading Problem
I have a comet on my drain cleaning rig it does not get 3500 like they said it gets about 3200 at the nozzle and about 7 and a half gallons a min… Which is fine for cleaning the lines I clean. I have not had a problem with it yet but then again I only have about 2 years on the machine and I am the only guy running that machine and I am really careful with things… On the up side it was pretty cheap. If I had the volume if work IBS has, then I would have gone a different route.
Hey I’m curious as to what you Do, Do you have a link to a YouTube video example?
@Greg755
Neat video, but i meant drain cleaning, heh
Test
Hey guys - we have been upgrading the forum over the pas couple of days. I think you might have experienced a problem while things were moving around. Let me know if you spot any other problems.
thanks
That ur video? If so what you spraying on units?
Machines do look brand new… i have always used silicone on engines and outboards.
If you look at the play lists there is one for plumbing and drain… I think there are two videos for drain cleaning… I always forget the camcorder or it is to dark or crappy (no pun intended) to film plumbing/drain work… So I don’t do many vids on it…
Just normal spray lubricant. Not WD40 and not penetrating oil, when I get back to the shop I will look at what ever it is that I picked up this month to use. On the door locks and big springs for the trailer door I use graphite spray. Same stuff that is in my install a garage door video…
Appreciate it.
If there is a picture here, it is working again
Doesn’t seem to work tonight. Noticed first when PMing, and now it doesn’t work for me to upload photo here. Maybe problem persists…
Guys, do you know the size of the image you are trying to upload without success?
Probably hitting the upload file size limit, but we will increase it again.
Working for me… i did have issues yesterdays and used photobucket
Ok, we restarted the server and increased the size of attachments to be up to 8 MB. I think this should be enough? The problem is that some phones take huge photos which then the server needs to resize.
