I have a 14’ tandem axle. IBC tote centered above axles. I have a 37hp Kohler and Landa 110v oil hot box.
My first question is where to mount things in the most efficient locations? Hot box directly in front of the IBC? Engine / Pump infant of that or off to the side for easier access/start/stop/maintenance?
Mounting everything - Is it the norm to just mount through the wood decking on the trailer? I’d prefer mounting to the frame but the cross members are few and not located ideally. Also, should I be using rubber mounts on the engine/pump base plate and the hot box or just bolt & U bolt them down?
Chemical tanks - Going to be carrying Ammonium Bifluoride and of course SH. What style and size of tanks would you guys suggest?
I’ll add some pics later. Thanks
