Tile roofs/soft
So after 1000+posts in the wcr I have to post over here.
Roof washing and home washing where I live we have very very few homes with shingles and nearly all homes are stucco.
Can roof tiles be soft washed? Over the years I have cleaned some roofs with a pw but it takes forever.
If it is possible would the runoff damage or discolor the stucco?
It seems so much safer and easier to clean from the ground and a lot less water used.
Any input would be
Brian,
I wouldn’t worry about damaging or discoloring the stucco as long as you have a ground person spaying any areas that you overspray on.
All roofs can be softwashed, but not with a pressure washer as you couldn’t get the mix strong enough. You’ll need a dedicated roof cleaning pump or chemical pump to apply the cleaning solution. Here are some ready to go options for you:
http://shop.powerwashstore.com/Generation-II-Twin-Pump-System-w-Titan-Reel-5401-5401.htm
