Interested in feedback on the system over but especially the udor diaphragm pump @Innocentbystander
I have never used one. I donât do roofs but 10gpm is way to much for a roof wash. It is impractical to use washing a house or any structure with only a 100 gallon tank. I wouldnât want it but it may be perfect for someone
Iâm not wild about the tank set up myself(I prefer a drop stick set up) or the price for that matter but the concept is interesting. Overkill for roof washing but modified or custom built for a house washer was my train of though
Pretty expensive too Iâd say. With an old 55 gallon barrel you can build a functional system under $800. Especially if youâre using it infrequently.
Iâd likely build something like this if all I was doing was large commercial stucco all day everyday.
Pump alone is 1400 seems like a beast. Not trying to re invent the wheel or anything here just seemed like an interesting concept.
*Edited category from roof cleaning to supplies and equipment *
Those suck for roof cleaning. Just like your Pressure washer. When you let go of the trigger it goes into bypass. Turning your chem tank turns into a foam party. Not to mention 10gpm will do nothing but waist chem and your grounds guy will never be able to keep up
What he saidâ!! Plus if u draw out of a different tank u will have to swap the bypass hose to!! U will hate it
Didnât even think of the bypass. Eek
First, the price is too high. Can get comparable systems for around $3500. All the distributors sell them. You can also get a lot more compact systems.Iâm seriously thinking about that type of system for my next roof cleaning system. In fact if I had room on trailer Iâd have one now.
The only disadvantage is that you have to bypass by to whatever youâre pulling. So you have to use a bulk tank setup. But you can set up good 3 way valves to adjust where youâre pulling from so if you want to pull water for rinsing just switch the valve. You throttle down the flow with your tips and all have a variable flow rate.
The best thing about them is theyâll easily shoot about 50â. You can buy just the engine and pump on a base for around $1600. I havenât heard particular good things on the Udor Zeta pumps and I wonât get on a system if I get one.
Yikes he has the price of an all flow diaphragm in ball valves and fittings. And it will shoot 50 ftâ:grinning:
