What a prick. That was his way of keeping you there without detaining you so he could get as much info as he could. Glad you know your rights. Alot of people dont and fall into the traps they setup. I was in a parking lot pulled away from all the stores and had a officer start questioning me and i simply said “am i being detained?” he FLIPPED OUT and started calling me names and telling me i was a “suspicious vechile” when i asked agian and he said no i just drove off… People like that should not be police officers. I was simply on my phone killing time till cabelas opened to get my bow readjusted. Thought about calling the sheiffs office to report him, doubt they would do anything.
Oh dont worry i wasnt even going to attempt that . I thought that was to control your SH, soap and water for your 12volt. I might be mistaken.
It is to control the soap and sh for my 12v lol
But the rest of the skid Is for my pressure washer
Saved you $1200. Im not sure if i could do it haha. Have trouble doing simple plumbing under my house.
Well if I buy this flatbed cabover I’ll sell you my skid.
You would have to buy your own low profile water tank. I’m not going through that ording delay again! I would keep the water tank for de icer
Cant wait to your set-up ideas on that. More room for more toys.
AFTER i bought my truck racer told me IBS and squid said the plugs are a problem to change(could break off in motor)2000 ford f150 v8 5.4 triton… Hopful i can make enough money. Sell it and get me another truck before a plug goes bad.
Grizz, the plug issue has been fixed for a long time now. The plugs your referring to were 2piece design and would seperate. Plus theres a tool they use now to get it out.
Close to a non-issue now. I bought a 2006 with 5.4 with 80k on it. I changed the plugs to be safe. All eight came out no problem.
Have a shop do it…
Or run a can of sea foam in the fuel and drive the truck for an hour and take out the plugs when there hot.
It’s very unlikely it will blow one. If it does it will be the closest to the firewall after you have the plugs changed. Leave the plugs alone and you’ll be fine!
That’ll teach you Yankees from NC coming down here and littering in SC, LOL.
They’re kind of bored in Mauldin, have to have something to do.
It was only certain years - I told you to check with IBS or Squid because they would know.
The issue is by no way fixed it has nothing to do with the spark plugs it has to do with the lack of threads in the head for certain year models good luck with what you have
Your right ibs, I’m thinking the 3v series problems. Sorry about that Grizz. I totally forgot thats why i don’t consider those years of trucks. If I remeber right it was only the big v8 affected, 5.4?
I have read about that.
I was speaking of the later 5.4. With them its a matter of using antisieze and not going too far between plug changes.
Hows the simpson hose holding up? Monsterhose right? Ive only heard 1 or 2 folks say its junk, but not specifically the monsterhose. I read of 1 person claiming he could see corrosion thru the clear sheath, and it left a yellowish stain or tinge to house he washed.
Oh that stuff was gone first time i used it. I wouldn’t wish it on my worst enemy. Its like trying to wash with a slinky
