This is for an old customer of mine who’s selling his house. This is going to make some great BeforeAfter pictures.
Man I’m glad they don’t use brick down here . I hate brick
I don’t mind it. It pays good plus I enjoy the look of the customers face when they see the difference
The gnar bar has been raised. Hope you have a 12V. That’s gona be a good one for sure, go get it.
Not yet just my washer. It’ll be fun
IDK if your normal hw is gona touch that. Soap lots of times and keep it wet. Make sure to post some pics for us.
You don’t need soap, just a turbo for the brick
Won’t that possibly remove mortar?
Not if you stay back enough
Long sleeves , eye pro, and a water bottle…long day turboing
Just algae you could hit it with a 4% mix and get away with a rinse. All that moss you’ll need to turbo tip it.
I have a 3500@5.5. I just looked on pressure tek what orfice size do I need? I’m looking at the 3600psi sutner
It still asks for orfice size.
Between 6.0 and 6.5 according to the charts…have you read the nozzle charts for psi/gpm?..they’re all over this forum and the internet.
That’s a 5.6gpm pump so 6.0 orifice for yours…I just ordered this model turbo nozzle from PT based on @Innocentbystander suggestion
I go a size smaller due to the amount of hose I use
Apply a strong mix of SH with a pump sprayer. Two applications, 10 to 15 min dwell. Rinse away what’s left with a 15 degree tip. This brick was just as bad if not worse.
Yes but I can’t make heads or tails out of what I’m looking at lol.
Are you saying to go with a 5.0? I can’t seem to get my head wrapped around this nozzle size thing.
Probably good with the 5.5 or 6
