I wonder how the plastic downspout extensions coupled together would work in conjunction with bags if needed would work too control roof mix runoff
Lay-flat tubing accomplishes the same thing, with less hassle and leaks
Thanks. Do you have a link for some please
This is what Iām talking about. Iām sure you can find it cheaper if you search around. I would probably go with 6ā and anything 4mil or thicker.
