Tank Question
Are most of you guys running straight from your water tank to your pump or is a pump necessary. I have a 225 gallon tank and a 4 gpm 4200 psi pw. Going to see tomorrow if gravity fed will be enough, hose length is about 5ft from tank to pw. 1 inch line.
Thanks
No need for a separate pump.
You recommend a certain one, 12v or 120 thanks
Sorry, I meant you don’t need a separate pump.
My bad I misread it, thanks buddy really appreciate it
Your good with that setup. No extra pump needed.
Y’all were right as usual, no pump needed worked perfect
