Yesterday my surface washer lost 1/2 it spin speed out of no where.
I checked the nozzles they are clean
Running a 8gpm 3500 and it’s pumping just fine
Bearing seams fine
Any ideas ?
If your pump is pumping fine and the nozzles are clear then I would think it would have to be the bearings.
My suggestion would be to replace the bearings anyway. I just replaced mine this week and what a difference!
Ive always said you get what you pay for so go for the good bearings not the cheap ones.
Change the swivel and keep getting it
Or do what @Innocentbystander said , I might start keeping an extra swivel with me here soon just in case
check nozzle orientation on bar, if your swivel is fine
Keep a spare dwivel, bar and set of nozzles for every two surface cleaners you have
Thx guys.
