I have a quick question. I’m considering a surface cleaner rated for 3,700 PSI, yet the pressure washer puts out 4,400 psi. If I paired these two up together, would there be problems, or would they work together just fine?
It’ll work
I tried the same thing and only got ERROR messages???
Pull trigger 3 times to erase error. Once that’s done do a cart wheel. Should come up sweet.
Tried that but it’s sour not sweet. Well report back once I get it figured out
