Hey there everyone,
Firstly, I just want to say thank you to all of you whom contribute so much information to the rest of the Pressure Washing community. I’ve been a “lurker” for the past few weeks, but I’ve spent many hours searching through various threads to gain as much knowledge about the business as I can. Simply put, I want to go into this with the most knowledge/professionalism as possible.
A bit of my background; I’m currently a professional working in the real estate/banking industry and have for my entire career (about 12 years). I have a business degree in finance and marketing. My career is being thrown upside-down, however, as my beautiful wife is finishing up her PhD and we’re re-locating out-of-state from Michigan to Utah (big change!) which is where she is from.
She already has work lined up, but I will need to find work once we move out there as my current employer won’t let me work remotely. Being that I’ll have the opportunity to “not work” as we can get by with just her income, I thought I’d venture out and start up a business and see how it goes. I’ve dreamed about being self-employed and enjoy doing anything in the real estate industry - even if it means flipping things around and doing more of the labor-intensive work rather than the paper-intensive work I do currently.
I do have a decent budget to get started. We aren’t moving until next year and as such I’m going to hold off on a trailer/truck-bed setup until we’re out west. I’m going to file my LLC paperwork/get small business insurance here in Michigan and start cleaning part-time to make sure I even enjoy the work. As I stated my specialty is in financing/marketing and I’m very comfortable with the margins that this line of work offers and have already drawn up a business/marketing plan.
For starters, I plan on dropping around $1,700.00 on equipment… how does my starting list look?:
o Honda GX390 powered Beltline Pump rated at 4gpm and 4200 PSI
o Downstream Injector
o 100 ft. hose (won’t have a reel set-up until I get a trailer next year)
o 2-story spray nozzle
o Surface Cleaner
o 5-gallon chem bucket (I’ll mix onsite)
o Small business liability insurance/LLC set-up
I plan on using 12.5 bleach in a 80/20 water/bleach mix for starters and down-stream. My idea is to charge $250/house for siding and then add-ons being $125 for a driveway and $50 for sidewalks. I wouldn’t mind getting into window cleaning/gutter cleaning, but I want to keep away from ladders the most I can.
I know a Belt Pump Washer isn’t absolutely necessary starting out, but I’m the type that would rather be safe-than-sorry. My fear is that I’ll encounter well-water/low pressure houses and be SOL and end up buying another pump ($200~) to make a Direct-Drive able to pull water… so why not just buy the Belt-Pump upfront, right? The idea is that I’d have a 35 gallon buffer-tank as a back-up in the event I need to draw from it.
An alternative to this is that I already do have a 2.3 GPM/2600 PSI pressure washer that I could use in the event that a home has low-pressure water coming out… What are your thoughts on this?
If any of you have any tips/advice on my current set-up please let me know! Thank you and best of luck to everyone with their business!
