I plan on direct feeding my 4gpm pump with 1” non collapsible poly hose with a y filter in line.
But my buffer tank bulkhead is receded and can’t come up with with anything to have access to my dump valve 3way as I added a hose reel rack.
I do plan on upgrading to 8gpm hot water soon
Anyone got any suggestions I would greatly appreciate it.
That’s a great idea that makes a lot of sense. This is my first build so I’m sure I will find things down the road I will always want to improve on. I think it’s the nature of the business lol.
I’ve been reading and wondering if I jumped in head first. I went out and dumped big coin into a gen 3 Softwash skid 12v as well smh. Now time to get the money lol
Did you run out of room to mount that tank 90 degrees from how it’s sitting? If you haul even a little bit of water in there, it’s gonna slosh hard against the front every time you brake. The leg tanks are great when faced the other direction because the braking slosh is cut down massively.
The front and rear of the tank legs are getting 4X8 L brackets front and rear to prevent tank from sliding forward and backwards. Then it will be strapped down where the bands are supposed to go. So I think I’m stuck going this route using the front center bulkhead access point in order to be able to fit in a y filter.
Looking to future proof the setup in preparation for 8gpm skid.
Tank will fit sideways but the run from the bulkhead to the pressure washer will be very short maybe to short to even put in my y filter and 3 way valve.
Turn it sideways. You have room for about 20 ft of feed line. You don’t need a 3 way on the feed line. You have a half dozen other options for a drain or additional feed line
