The o ring for the garden hose intake on my pressure washer is worn out. Should I replace it with a regular o ring, which is the way it came, or should I replace it with an o ring that has a sieve/mesh to keep debris from entering the pump? If I go with the sieve/mesh o ring, I’ll have to get one that has a flat sieve, as opposed to a concave sieve, because the concave kind does not fit.
Those get too restricted. You should be using a regular filter though before the pump though. I use two. One before my buffer tank and one right before the pump.
The have different inlet and outlet thread sizes.
https://pressuretek.com/1-ftp-in-out-clear-bowl-water-filter/
How so when they’re not even 50 mesh?
That looks nice, but right now I’m just looking for the simple o ring solution. Can always upgrade later.
In the very least, use the green cap filter. Those oring mesh things deteriorate and can emd up in pump.
If you don’t have any filter before your pump, you’re going to upgrade sooner than you think.
Man, I made the mistake of using a customer’s hose once. I guess a wasp of some sort built a leaf nest in there and my intake screen was stuffed.
At least get one of these, I’ve used it on a 4gpm unit. Attach to spigot and run your hose from the filter. $13 and change at Lowe’s.
We’re going from bad to worse here lol. Get the one that @marinegrunt suggested, doesn’t make any sense to upgrade something like a filter at a later date. A good filter is a necessity not a luxury.
Thanks for the help everybody. I think I’ll go with this: https://www.amazon.com/STYDDI-Pressure-Sediment-Attachment-Gardening/dp/B07XGGVSN9/ref=sr_1_5?dchild=1&keywords=Garden+Hose+Inlet+Filter&qid=1591720502&sr=8-5
For some context, I’m a college student trying to make some tuition $$$ over the summer, and I just bought my first PW. Got a used 4GPM Lifan 4500E with 24" surface cleaner and ramps to load it into my van, all for $1,000. Tested it briefly before buying, but should have payed closer attention. When I got it home, I realized all the o rings needed replacing and that it was older and more worn than I originally thought. For the price, it was probably still worth it, but I’m reluctant so put much more $ into it, because I don’t have any customers yet. Might have to flip it at the end of the summer. We’ll see.
I appreciate your guys’ help. Better to spend $20 on a decent filter than ruin a pump, though it looks like it’s been used without a filter for longer than I’d like to think.
That filter will work fine. Don’t worry that you had to replace the o-rings. That’s a common occurrence so be sure to keep plenty on you when working.
