Spider webs on EIFS ceiling (dry vit)
#1
Any suggestions on removing webs from an EIFS ceiling? We have used cobweb dusters in the past. I wasn’t sure if downstreaming a house wash mix would do anything at all. It is about a 40 by 120 foot section of ceiling over a drop off and pick up area. About 18 feet above grade. If its possible to do with pressure washer easier then poles I would prefer to do it that way.
#2
You’ll find yourself just pushing them around, easiest thing to do is cobweb dust it a bit to get the bulk off
#3
That’s what I thought. Felt like I tried a power washer years ago and it didn’t work but I also was doing a higher ceiling over a walkway and not using chemicals on it. I was hoping sh would help break down the webs.
#4
Soap and Sh will break down the webs, and makes rinsing them easier.
#5
I’m with Donte on this one. SH will break down the webs or has in my cases.
#6
Thanks guys I am going to give it a try. I will post results. What surfactant would you use? I typically use elemonator just not sure if it will be “sticky” enough to hang on the underside of the roof.
#7
It’ll be fine. I don’t even own a web duster or whatever you call it.
