So what are you towing with 1/2,3/4 or dually?
I’m probably going to tow about 6500lbs. What would you recommend for a pickup?
Julio Fernandez
Tampa Bay Area
A truck that weighs at least 6,500 pounds itself would be preferred.
3/4 ton is adequate. Brakes and tires are paramount in the equation.
Dually is most likely not necessary.
3/4 is on top of the list. That 36 gallon tank is scary. I’m guessing its ok since I’m buying it with a Diesel engine.
Julio Fernandez
Tampa Bay Area
3/4 should be fine. The brakes and axle strength should handle the weight easily, especially if you get a diesel. 1/2 would do it but on a daily basis, the 3/4 ton will last longer. 1 ton would be fine too and give you room to pull bigger if you ever decide to.
Cool. Thanks guys.
Julio Fernandez
Tampa Bay Area
I one ton will have a bigger brake system than a 3/4 ton. Either truck will pull it the trick is trying to stop it in a hurry. Plus you can usually pick up a one ton for less than a 3/4 ton since most 3/4 ton truck are lariat model or something similar. Most one ton are xlt or xl models if you have trailer brakes it help but its going to take you a while to learn the setting based on how full your tanks are
Get a Prodigy P2 brake controller and live the good life. There is just nothing like a good brake controller to make trailer pulling pleasant.
I found a lot of affordable 1 ton but won’t it be a bigger hit on my gas expense.
Julio Fernandez
Tampa Bay Area
Just a personal preference but once I pulled a trailer with a dually I won’t go back to a single wheel again. Not so much for the weight but the ride is a lot better. A lot less sway and movement back there. 3/4 ton will handle the weight fine. We’ve had 10,000lbs behind f250 just fine. Now we have a f350 duals that rocks.
There is no difference in a f250 or f350 other than the brakes. Rear springs and rear axle capisity. Mpg is the same enless you get a dually. My hauler is a 2002 f350 crew cab shortbed. It gets 22mpg on the hwy unloaded and 15mpg pulling a 15000 trailer. And it lifted on 35 inch tires. Although i get about 10mpg around town no matter what i do. It is a diesel and i wouldn’t have anything else in a truck
Were up to p3 now :slight_smile: I got mine awhile back it’s very nice and easy to use
Good info. I will look into that prodigy p2.
Julio Fernandez
Tampa Bay Area
There are other trucks besides a Ford. Just saying.
Look at 2007 and newer Tundra. You can pull 10000 with it. Brakes are big and work great. Almost 400hp V8 can get this thing going. I had 2000lbs on my truck while pulling 3000lbs trailer with no trailer brakes. It was smooth and no problems. Transmission downshifts when towing, so you brake with engine to. I love it
We had ours installed at the trailer place for like $200 per truck. I drive a 1500 and will be pulling the trailer probably less then 20% of the time.
What do you guys think about the ram 2500 w/ the Cummings engine?
Julio Fernandez
Tampa Bay Area
Reliable engine plenty of power and best mpg of all the diesels. That being said the trucks have the biggest POS tranny in them. If you find one with a manual it will last forever. Cummins is for the most part a trouble free engine. Enless you buy the common rail model they has some problems with those.
I think that you added a “g” to Cummins. You’ll hear very few complaints from their owners.
Pick what you’re comfortable writing a check for. Don’t confuse the issue with what is “best”, as there is none. They are all good.
What is your budget? and is this a workhorse or a new play toy that may pull a trailer once in a while?
Yeah that g came in the drop down from my cells auto spell/auto correct. Lol. I have seen prob two manual transmission 2500. I’m trying to stay between 15k-25k. If I finance I might go as high as 33k. I’m going to be towing as often as I get work. I’m going to slap a nice half wrap on it. Where ever I go I will be promoting my biz.
Julio Fernandez
Tampa Bay Area
Wrap sounds good. Are there turnpikes/parkways/fancy roads there that don"t allow commercial vehicles? I know that John T has to be aware of that issue in New York.
Get a white work truck with the proper axle/brake/tow rating at a price point/age/condition that makes sense for now.
Diesel is a preference. Not your only option.
