SH temp thread
I remember seeing a thread about not using SH under 40 or 50 degrees a few weeks ago, anyone mind bumping it? I tried to take out out small cold water unit today and didnt have much luck
Dave, if you ave a hot water machine, that really helps around and between 35 and 50 degrees (probably even colder, though I haven’t tried it).
I’ve been washing in the upper 30s and low 40s with cold and hot water for the past few weeks and while it does take a little more dwell time and going over tough spots again, the results have still been fine. Much better and easier with hot water though.
Hot water is def the way to go in cold temps. Try mixing your Sh stronger in the winter months if you don’t have HW. You may have to go over it again.
