I have searched all around and cannot find a 50- 65 gallon SH tank with no bulkhead fitting. Does anyone know of a tank supplier in south LA or MS? I am trying to avoid using a tank from TSC due to the bulkhead fitting & don’t want to use a drum on the new trailer build.
I couldn’t find one either. I haven’t had a single leak, just keep a backup bulkhead fitting and gaskets, and empty/rinse your tank as part of your daily breakdown routine.
I don’t like it but I plugged my SH tank. It leaked then I replaced the bulkhead with a banjo bulkhead and and used silicone grease and it hasn’t leaked in 3 years. I still want to replace it with a pco tank but for now it works.
I couldn’t find a 65 gallon one either and I didn’t want to risk leaks, so I went with the 100 gallon one below. I know this one is larger than what you’re looking for, but it’s the one I went with and I’ve been happy with it:
Thanks for the responses. I remembered that a friend of mine is in the pest control business. I called him and he has a 50 gallon with no bulkheads that he is giving me.
