A customer had some asphalt sealer splash on her house while having redone. What’s best chems for this to help remove? It has some on brick and on siding. Thanks
Brian Richardson
Crystal Clean Pressure Washing
270.350.SOAP
Brian Richardson
270.350.SOAP
Gojo
iPhone - Tapatalk
Hand cleaner? Who’d a thunk it! Thanks
Brian Richardson
270.350.SOAP
So this is 9 years later but… Did it work? Does it only work on fresh splatter? Any better alternatives? Do you brush it on then pressure wash off?
Would it take care of this? Thanks.
(I can’t go there to test it).
That looks like blacktop sealer, I believe that’s petroleum based. Need something to break down the oils in that……I’d walk away if it were me, money out there to be made that’s easier. Just my opinion
Need turbo nozzle too….
I’m not sure what that is based on the picture. The little lines going through it make me think that someone sprayed something on there before, trying to remove it. A little odd looking for sealer overspray because that is pretty high up the wall for overspray. I normally see it in the bottom 1-3 inches of a wall.
I’d quote to lessen it and not remove it, if it does come out you look like a rockstar. I take a lot of odd jobs that people on here don’t do. I would like to try that one. I’m a glutton for punishment though.
Hahaha! I went to check it out just to see. I thought no way water alone will remove that but i did a test anyway just by curiosity. No chems needed.
So just pressure took it off? Good info.
Light pressure on top of that. I was really surprised.
