SAMs club bid?
Hey guys I just got contacted from a property manager that has 26 SAMs marts that need to be cleaned monthly. Never bid anything this large. Just wanted to get your thoughts? I will be traveling tomorrow to check some of the stores out. Should I discount it a bit due to the amount of stores? Any help or thoughts would be greatly appreciated! Oh and the water must be reclaimed!
Thanks
Discount no… it cost $ to travel.
Sent from my SCH-I605 using Tapatalk 2
Ted,
I know when Wal-Mart was taking bids a few years ago for all the Central and North Florida stores, the company had to have a reclaim unit. If this is something you can take on, getting Sams would probably set you up to eventually bid your regional Wal-Marts.
Are that 26 Sam’s covering all of Georgia?
A lot of the stuff is built to spec, so a Sams here in MN is basically built on the same sqft platform as a Wallmart or Home Depot.
When i do larger proposals like this, i try and just look at each of them as hourly work as opposed to rolling and measuring each one. Roll a couple just to make sure, but when i bid these hourly we are right around .10-.15 per sqft. Sometimes it works out so its higher, but if i can stay in that range, im happy
That’s exactly what I was thinking. I’m gonna look at a few today and do more of an hourly rate. Thanks guys.
Did you get them? Who do they use as their NSP or Property Manager?
.10-.15 with reclaim? Really?
I don’t use reclaim…
Guy, I totally missed that at the end if the original post.
to clarify, the pricing I gave was for straight concrete cleaning, no reclaim.
Thanks guy :slight_smile:
I just turned the bid in Friday. These are actually Sam marts!!! A complete misread in the original email on my part. These are gas stations. Still a good bit to be cleaned.
