Removing Rust Harrisburg,NC 28075
While we were cleaning a building in Harrisburg,NC we removed this rust from the dryvit and the owner was impressed.
Nice work, what did you use?
F9 Brac
Excellent rust removal job, Aaron.
F9 BARC excellent product - excellent results.
Where you bought the product (F9 BARC) With a local dealer or online?
http://shopwindowcleaningresource.com/f9-barc-concrete-rust-remover.html
I’ve been looking at that stuff to be another tool in my arsenal but the description in wcr says that there is no mixing. So this stuff is rtu?
I get mine from Paul at the Power Wash Store
You can also get it at WCR.
F9 BARC Concrete Rust Remover
Ok. Is it ready to use?
You can mix it 50/50 and it still works. I haven’t done enough rust jobs to work with the ratios any more than that. But I still had great results mixing 50/50 water and front 9
Sent from my SGH-T999 using Tapatalk 2
F9 BARC Rust Remover is a concentrate so when you are ready to use at full strength, mix 2 parts BARC to 1 part Water. At this dilution you will still be able to get the absolute best results from the product. This dilution is especially recommended for porous substrates like concrete, brick and pavers.
For rust on siding, stucco, plastics, windows, coated concrete and other less porous surfaces our F9 Applicators are diluting with up to 2 or even 3 gallons of water per 1 gallon of F9. Remember though, the more you dilute the product the longer it takes to work.
For myself and my pressure washing company we always apply with the recommended 2 parts BARC to 1 part Water.
Tim, F9 MUST be diluted with a minimum 1 part water to 2 parts F9. You can stretch it out to as much as 3-4 parts water to 1 part F9 BARC for vinyl and stucco, it just takes a little longer to work (like 3 minutes instead of 45 seconds). The dilution of 1 part water to 2 parts F9 is for concrete battery stains and fertilizer (and bad rust). Every state is different though as the minerals in the water that combine with rust change but F9 will still blow away any other rust remover out there.
Concrete Rust Remover is available at [URL=“http://shopwindowcleaningresource.com/f9-barc-concrete-rust-remover.html”]WCR HERE
