BACK ORDERED Remote downstream controller (The Schertz Box)
I am in how do I move forward
Send me a pm with email address, full name, and a shipping addresses. Also specify that you want the 3 way valve.
so the three way valve doesnt actully effect the flow of the water, as much as it
  1. soap
  2. off
  3. water still going through the injector though?
I was looking for something that by passes the injector all together when rinsing, does yours do that??
No sir. When you turn my 3 way system off it sends water to the injector.
For that you would need a high pressure motorized ball valve. Iā€™ve yet to find a viable option.
I could design that lol no time right now though.
Thanks I misunderstood originally, still a great sytem and worth the price as it has quality all over it. I may get it down the road to have, but I wash with a 10gpm and use 3-5 injectors I would loose far to much flow for my liking.
But it definatley be a great tool to have for some situations whear I am far from the rig.
can I get you to make one with a BY pass :slight_smile: of the injector??
I have used several remotes and this looks to be the best one so far, what solonoid do you use
Donā€™t need a solenoid with my ball valve. It doesnā€™t consume energy like a solenoid valve would. Less moving parts to fail.
that is so good to here, because that was one thing I hated about remotes is the solnoid always went bad fairly often
Nope. My valve has an indicator wire that uses low voltage. Once the remote sends a signal to the indicator wire it activates. Once itā€™s on the indicator wire consumes next to no voltage. This saves batteries as well and remote modules.
Itā€™s patent pending. Should be a game changer in our field of work. Limiting sales until weā€™re out of pending status. Weā€™re still protected as of now for copyright. But I will only sell to a few folks just so when everything is done I have quality guys backing them.
Can this be plugged/wired onto the hitch power connector?
The 4 ping one?
I wouldnā€™t rely on it. But I guess you could if you wanted too. Why would you need to do this?
So i dont have to purchase a 12v battery
Donā€™t you have a battery on your rig for starting machines or starting the pressure washer?
Yesā€¦ just an idea, though it might be easier
Oh ok.
Canā€™t say it would be easier or even reliable. You would have to have constant power coming from your plug. Meaning you would have to have your truck headlights on while washing.
Thats where ur exoertise comesā€¦ i just drive.
I am still on the fenceā€¦need
1.,Mix,
2., straight SH.
Would need a unit with 2 ball valves
I can do it. But the price for 2 valves is high. We talked about this.
