I’m just replying to you in hopes that I see the answer to your question when it comes in, because I’m not 100% sure myself.
I believe that your PSI will still be 2500 out of both nozzles (if you have the right size nozzles) and only your GPM will be divided by two. I could be wrong though, so I look forward to seeing someone else answer. This is a great thread you’ve started!
At one point last year I needed to run a second direct drive machine from a supply tank. It only had one output, so I took one of those crappy short green garden hoses and popped it in the top of the tank. It would actually suck water all the way from the bottom of the IBC tote, even when the tote was nearly empty. I could not replicate it this year though. (Not that I needed to, I was just doing it for curiosity.)
Its been a little while, but finally, called enviro spec, and got a 6.3 gpm, with a gear box, just got it plumbed in and it really looks like what I need for now, and I really appreciate you guys sharing your knowledge. However I failed to add the spacers and that caused a oil leak on the “gear drive pinion seal” inside the gear box". Caught it quick no problem, now if someone could share with me the spec’s on the gear box fluid, i.e. weight, I would really appreciate it.
If I remember correctly, in your case it was because the driveshaft for the predator was longer? But it seems like @Pw2020 is using a gx390 - does that mean that the spacers are always necessary then?
Enviro Spec sent spacers with the pump and gear box, having knowledge I had a gx390, however they advised the spacers are sometimes thicker depending on the length of the output shaft
