Mix For Cleaning Colored Paver Stones
Have any of you used a 50/50 mix of water and white vinegar ,to clean colored paver stones? Could I possibly use on tile as well?
Thanks
Hi Jerry I recommend using the search feature and seeing if the info has been shared first.
Try these three threads. I have them on my “Reading List” for cleaning pavers.
Paver cleaning woes - #7 by jcfin
Best way to clean pavers? - #54 by Racer
Surface cleaner on a paver driveway? - #16 by Kps0410
No. This forum is for professional power washers. You won’t find any home remedies here. Use sodium hypochlorite and/or a surface cleaner to clean pavers.
