I want to ask these questions in one post to reduce spam so if you take the time to read through I appreciate it, I know everyone is going to look at my read time and tell me to read more, which I will but I would like to verify the direction I’m going in so I don’t get confused with the different things because there’s a lot. I also want to see people’s opinions on the equipment I’m listing for a SW and PW
The main thing I’m confused on is what the point of a downstream injector is off of your PW when you can only get such little %, is it just for the surfaces that require lower % so you can easily go from soap to water by changing the tip because of the venturi effect in the injector?
I was planning on getting a 5.5 GPM 3,000 PSI with a buffer tank for my surface cleaner and add the injector for lower percents and then create a 12v system with a 12v battery, 12v pump, FatBoy Kuri Tec Ag Hose Kit, Flojet 305730004A Accumulator Tank and a filter along with the plumbing.
With the 12v setup I was going to make the highest solution I needed (let’s say 4% for a roof) and if I was doing a whole house I would dilute it throughout the process going down the line so like I’d start with a 4% for a roof then a 2% for another surface and then rinse with and since the 12v only pumps your solution I’d just deatach my hose from my 12v and use my PW to rinse off the soap?
Based off of stuff I’ve read this seems like it’s not the most efficient way and like I’m missing a lot but that’s the problem, I’ve read on other sites and watched videos for this past month and I get the lingo it’s just I get everything mixed up.
I don’t mean to disrespect anyone on here, I know I need to get that red time up on here before I gain any respect from anyone, I truly appreciate anyone taking time out of their day to respond and help me out. Thank you.
This thread has now turned into a BBQ debate
