Just saw this on Facebook. I have a sludge sucker, but seems like this might come in handy as you can continue using the pressure washer and just use this real quick to move water away. Looks like there’s a hose thread on the end too. Not sure how good it works with muck though never used it… In all my years of living this might be my best purchase ever! | Soap and Clean | Soap and Clean · Original audio
Interesting.
I just use one of those 12v sump pumps off Amazon. Leave it sitting in the low spot, keep rinsing with the wand and that way you’re not having to stop and evacuate. I did add a cheap metal elbow to the top so it shoots into the grass.
Man these went up in price.
Just wanted to make sure you know those will overheat and burn out if water is not flowing through it. The glycerin in it won’t save it
Roger that, I try to keep an eye on it. The only thing About them is the leaves and junk clogs the bottom super easy so I have to move it around some.
