Hi All, this is my first time asking for help but a long time reader. I’ve got one of those “It worked when I shut it off but now it doesn’t” problems. I have a portable unit with a GX390 and a 4gal/4000psi cat pump. I’m running 100 feet of hose. I usually use an M5DS tip to apply my chemicals and rinse. I don’t currently use a buffer tank but I just purchased one to implement into my system.
So I had a down stream injector that worked great for years and then it just stopped pulling from my chemical bucket. I checked the line and it was not clogged. I ordered a new adjustable down stream injector. I connected in my system just like the old one and nothing. Yes the arrow is going in the correct direction. I took it apart to make sure the ball was not stuck and tried it again, still nothing. Just by dumb luck I was re-connecting my hoses and turned my ball valve on with out the gun and it started pulling. I connected the gun and nothing. I tried my soap tip and still nothing.
Does any body have any tips I can try out?
Thanks
