Pressure Problem
OK i have a 3800 psi 3.5 gpm simpson pressure washer
not the best but i got a deal on it brand new this is the second one the first one i sent back
it would have no pressure unless you cut it off and re start it so i sent it back
new one was doing fine but now when you pull trigger takes a while for pressure to come i have not ran it dry or let it sit running for any amount time
any ideas
If running off a buffer tank, it sounds like its not pulling well, or might have air in the line.
Sent from my iPad using Tapatalk HD
Post a pic of the pump and unloader so I can see what you’ve got.
No tank I think my problem is mayby i need a filter the unloader is not working right happend after using well water
What is best filter to run low pressure or high and what kind thanks
In line filter.
Does it come with fittings
No fittings. You would need to figure out how/where you want to install it and buy the part ya need.
This is on a tank, but same idea. Just got to get the fittings you need to feed from a hose.
