Hey I was looking at a 8.0gpm skid from pressure tek is pressure pro good unit an what better 12v or 15v
Gatorpwashing LLC Phx Az
Pressure Pro is some solid stuff.
Over the life of your equipment, you will typically have fewer problems and less downtime if you go with the 110volt burner unit.
Is that the unit with the generator or without the generator
110v unit has a generator on board
12v gets its juice from the battery which gets it juice from a charging circuit on the engine.
Very different units.
Very different outcomes.
