Practicing on Wood
@Racer thanks for the tips! I thought oxalic acid was necessary after sodium perc but it would certainly save time if it wasn’t.
The fence I posted originally is newer, this one is around 16 years old and has never been touched. This pic was taken after rinsing sodium perc and prior to the oxalic application. I am assuming the 8 oz per gallon mix you mentioned would work even better!
