Well guys I got my new equipment I have a 24” aqua pro surface cleaner with a 5.5gpm machine fired it up at my aunts place and tested it out on her side walk this is with no chemical I’m pleased with how my equipment operates now I got to figure out how to mix chemicals and of course I have to test my down stream injector guy at shop said it would pull 20 to 1 but I won’t know till I check it for myself…what do you guys think of how it done on my test…
Looks good
Not sure about the spots in the after picture on the bottom right hand corner maybe when I hit it all with chemical it will pull that up but that hadn’t been cleaned in over ten years
Seems like a huge SC for that machine, but not bad looking.
How slow/fast did u have to go?
I moved at a moderate pace just lightly pushin guess you could say
that is my machine it looks better now that was when I first purchased it all myHoses and things is on it now
Left handed pump… interesting. I’ll have to read up on this but isn’t pully rotating backwards?
You have a gx630 running your 5.5gpm pump so I’m sure that helps some with a 24 inch SC…you’ll have to move pretty slow though. I use a 16 inch Eagle Wash with my 5.5/2500 machine. As long as the concrete isn’t too dirty I can move pretty fast with it.
Believe mine is a 5.5gm/3500
I’m jealous of you guys with the open trailers. We have a risk of theft here so everything gets stuffed into my enclosed 5x8’ trailer.
We do in my area to do anything that isnt bolted down I will be locking in me truck such as ball valve down stream Injector wands tips anything that will go in my truck I have a crew cad thank god anything that will not go in there I will lock in building or chain it to my trailer
