I’m inheriting a pesticide spray rig. I’ve seen it in action for powerspraying homes and looks like it will work for housewash applications. My question is will this pump power a surface cleaner appropriately because the max psi is 150 per specs. I’m looking at sub $100 14-15" surface cleaners.
Short story is I can’t pick up and test this equipment for a few weeks. Will this pump power a surface cleaner tool with the following specs? Thanks in advance.
- Max flow: 7 gpm
- Max pressure: 150 psi
- Max rpm: 2600
- Port sizes: 3/4" FNPT
- Pump shaft rotation: CW
- Housing: Cast iron
- Rotor: Cast iron
- Roller material: Super rollers standard, Poly and Teflon® available
- Roller quantity: 4
- Shaft seals: Viton® standard, Buna available
- Shaft: 5/8" solid stainless steel
- Max fluid temperature: 140°F
- Weight: 5 lbs
