My name is Jessie I live in Houston, Tx. I would like to have a part time pressure washing business, what type of setup do you guys recommend? I believe I also need a reclamation system.
What trailer would you recommend, psi?
Thank you for your help, I want to learn all i can in this community.
Everyone is going to reply the same to you. Read and search the forum. It’s been asked and answered in many different forms. Super easy break down is minimum 4gpm for your machine and a good surface cleaner. Buffer tank depends on your area’s water pressure. Psi doesn’t matter too much unless it’s under 2500 and is depend on hose lenght and type of jobs you are doing.
Everyone’s going to tell you to look on the forum and it’s hard considering everyone else is asking questions too. Use the search bar and look at the tags and you can actually learn stuff. GPM>PSI they’ll say minimum 4GPM, look into softwashing, it’s more efficient then straight water and there’s a whole tag on it in the forum along with a chemical tag. Good Luck
