Hey Rowdy - side question: how long does a 35 gallon tank last you, on average?
Btw, the anticipation is killing me now, lol. The more you explain how you’re using them, the more excited I get, lol.
Your mix ratio is half of washing houses in an hour. Your process is the other half.
Like Alex said, the injectors are built for abuse instead of changing out the injectors every two weeks.
About 4 days if I’m just doing houses. I go through 220 gallons a month pretty consistently.
maybe I’ll go back and pick them up. You guys know more about it than me
They probably better be built to last running strait 12.5 through them, though.
They are stainless steel as well as all of the other things that Alex mentioned above., But you still flush it with water just like the brass ones.
They are definitely a nice heavy duty injector. I bought it for the reliability, and to have extras. If I was using 200 and some odd gallons of SH a month, I’d be trying to save on chemical too. I’m only doing a few houses here and there at this point.
Just know you gotta bucket test it. Lol
With your set up (I don’t remember your gpm/hose length/etc) you may find the grey metering tip gives you 1% and none at all gives you 1.2% or whatever. If I remember correctly that’s how it works for the 5.5s.
Yeah, I’m betting I’ll pull 10:1 or so without a tip. Bought the 2-4gpm injector, and run a 5.5 with 200’ of hose.
