Ah the magic of hiding behind a screen.
Can you imagine if what was said on here was done face-to-face? It’s like boot camp, doesn’t matter what background or education you have, everyone is fresh meat ready to be tenderized.
61 S Welles Ave, Kingston, PA let’s talk
Whatever…you said you had thousands…I took you at your word. Now, if you don’t like that I am sorry…and you can’t make that my fault…even though you would like to. My other reference was to all of the systems you have talked about building and then the last one that I saw…the whole package list…was less than what you had been talking about. Also, no one here wants anything but the best for you…no one has suggested anything that would be detrimental to you starting and having a good experience while being able to turn out the most work in the least time. So, you can get defensive if you like…but your reasoning behind that is groundless as I was only responding to what you have actually posted…I did not make any of it up. Now, take your drive to succeed and go forth in humility and realizing that, unfortunately, at your age…you don’t have the benefit of personal experience…BUT…you do have the benefit of many here with a collective TON of experience offering you advice…do yourself a favor and TAKE THE ADVICE. Good luck.
Thanks, usually when I get called a liar over something as dumb as the amount of money I saved as a teenager I get a bit confused, I saw it as you were just coming at me with no reason behind it and I thought you just wanted a reaction so I gave you one. Thanks for the good luck and advice.
No problem…and I sincerely want you to do well and if you will follow advice given here and apply yourself, you will be fine and you will be here giving advice to “newbie’s” in short order.
I appreciate that, didn’t mean to be disrespectful, I’m sorry.
