Yeah.That’s what I figured. I kind of knew that when I bought it but I’ve been cleaning alot of sidewalks lately so I figured I’d give it a try.
Thanks man. Luckily its still here.
Does anyone know if I’m right to assume that these hooks are for lift the pw? Or should I attach the chains directly to the skid?
@squidskc, @Innocentbystander, anyone?
I don’t know about the burner, but the ones on the honda are only good for about two or three lifts. Pop the cover off the air cleaner and use both eyelets when lifting. I’ve had them snap before. Chains rubs against air filter cover when under load.
Got it. Thanks you. Your advice is invaluable.
Hey. So I got to use the big guy yesterday and today. It’s awesome. I can move at the same speed as I used to with my 5.5 gpm and 19" sc. It’s not so good for dumpster pads or tight corners but I actually really like the wheels on it. If you’re only sc I’d recommend the 19" for versatility but the big guy makes four quick work on sidewalks and large surfaces.
Nice! Thank s pretty much what I expected…Big Guy for large areas, Classic for everything else.
Yup. The castor on the front keeps you a couple inches from from the wall but so far it’s still been faster to just do a little extra detailing than to use the 19". Honestly the 8 gpm is so much more powerful than my 5.5 that o did an entire strip mall this morning with just the gun. It gets cleaned every month so it’s not that dirty but it saved me a good hour with not having to rinse.
