Im looking into getting a buiness up and running in a few months. i wold like to know if anyone recomends this trailer package from Northern Tool. Im looking for a full set up like this. Any advice would be much appreciated.
Loading Video
FREE SHIPPING — NorthStar Trailer-Mounted Hot Water Pressure Washer — 4,000 PSI, 4.0 GPM, Honda Engine
Item# 157595 (12)
Key Specs
Pressure (PSI) 4,000
Flow (GPM) 4.0
Engine Honda
Fuel Capacity (gal.) 4
Fuel Type Gasoline
Engine Displacement (cc) 630
Gross Torque 29.2
Pump CAT 66DX
Drive Direct
Gun Industrial rear entry w/4 ft. lance
Orifice Size 4
Hose 150 ft. gray high-pressure
Coupler Size (in.) 3/8
Cart Trailer mounted w/15 in. wheels
Fuel Capacity for Burner (gal.) 4
Fuel Type (Burner) Diesel, kerosene, #1/#2 fuel oil
Max. Inlet Water Temp (°F) 140
Max. Output Water Temp (°F) 210
Steam Capable No
Burner Type 12V diesel w/schedule 80 heating coil
Chemical Injector Yes
Adjustable Pressure Yes
Engine Oil Type SAE30 motor oil
Pump Oil Type SAE30 nondetergent oil
Pump Oil Included Yes
Low Oil Shutdown Yes
Thermal Protector Yes
Battery Required Yes
Battery Included No
Dimensions L x W x H (in.) 129 x 75 3/4 x 60
See Complete Details
In Stock Online
Only $754999
Wow and its only seven hundred fifty four thousand nine hundred and ninety nine dollars.,. Lol… Not a big fan of direct drive units…
LOL. Yeah its 7,549.99. I have read belt drive is better way to go.
Look around for a good used trailer, then build one. For 7500 you could build one with a belt drive PW and probably add a softwash system. Plus you’ll have some extra things like back up parts… When you build it you know exactly what you need when there’s pipe or fitting problems. It lets you understand your equipment better. Just my two cents.
Building is the way to go. I wouldn’t buy a northstar anything after an experience where I bought a northstar pressure washer. The pump was basically hanging off by one bolt and the drive shaft, two bolts were 1/4 inch from being seated, and another was missing altogether.
This was after putting 40 hours on it and I was lying down to change the oils.
Trying to get it fixed, meaning 3 bolts, without voiding the warranty was a headache I wouldn’t wish on anyone. You can spend $2k on a better machine, with the same Honda engine, a better BELT DRIVE pump than a Northstar, and $1500 on a trailer and still be ahead in not only money, but frustration.
Oh, and you can get a 275 gallon IBC tote on Craigslist for $60 or a 330 gallon for $80. At least in my area.
