Just wanting some info on a 5gpm set up. Looking for high soap tip for a J rod.
Dont take this the wrong way but you just joined within the hr. There is a search feature. Try typing in what your looking for and I believe you should be able to find your answer. If in a couple days you can not find what your looking for then post your question.
To add to this I just did a search of what your looking for and found at least 3 threads that answer your question.
No I appreciate it, just familiarizing myself with the forum. I will do that with no problem.
